Not Receiving Crank Signal or RPM Reading
I currently purchased a microsquirt controller and am having a issue with not getting a crank signal or RPM reading.
I am using Tunerstudio MS V1.006 and my ECU Definition is MS 11 Rev.3.77000.
The ignition Tab set as follows:
Ignition Input Capture: Rising Edge
Cranking Trigger: Trigger Rise
Coil Changing Scheme: Standard Coil Charge
Spark Output: Going High(Inverted)
I am using a GM 7pin HEI module. the wiring from the HEI module is wired to the microsquirt a follows:
Pin 30 (OPTOIN +) to Pin R of the HEI Module
Pin 31 (OPTOIN -) to the distributor ground
Pin 12 (Ignition Output #1) to Pin E of the HEI module
When I crank the engine I get no cranking signal or rpm reading on the Tunerstudio
pierced OPIOIN + wire and read with a meter and saw what looks like a trigger but no crank signal
Removed spark plug wire and verified that I had spark while cranking
Replaced spark plug wire
Disconnected OPTOIN + from 7 Pin hei module and OPTOIN - from ground
Connected OPTOIN + to Tach wire from coil and connected OPTOIN - to a 12vdc source.
cranked the engine over again. Still no crank indication or RPM signal
What would be the next steps?
Re: Not Receiving Crank Signal or RPM Reading
With the HEI setups, is there ever a reason to change the settings of Input Capture, Coil Charging or Spark Output?
Input Capture may change depending on how RPM is wired up. The other options do not change.
Tried what you suggested and still have no rpm or crank. Any other suggestions? I wired to my original set up and am enclosing a screen shot of my ignition settings. One more question, When does the diagnostic tab become active , after the car starts?
Thanks,
However, when I crank the engine, I get an RPM reading (225 rpm) but the mstunner application says not cranking and the injectors do not fire.( Verified with a node ) I performed a injector test and all functioned correctly. Any good suggestions on what to check next?
Thanks,
Who is online
Users browsing this forum: No registered users and 28 guests
