[FIXED] Engine won't rev above 4k rpm
Posted: Tue Apr 03, 2012 8:48 am
Hi Matt, Grippo, 24c and others,
My engine won't rev above 4k rpm -- it bounces off 4k as if a software rev limiter was kicking in (it is disabled). The car runs well otherwise and all the sensors are reading as expected including AFR...in fact I ran autotune based on the target AFR table in the attached MSQ and it works beautifully.
The application is a Porsche 914. Some details:
[*] 4 cylinder air cooled 4-stroke engine
[*] COP, wasted spark, batch injection
[*] 36-1 crank-fired trigger wheel
Where should I start looking? VR sensor? Settings (crank pulse tolerance)? Someplace else?
MSQ attached, I could also provide a datalog showing the bounce off of 4k rpm.
thanks in advance for your help!
Rich
Rich
