"Cannot use Search function"
Posted: Fri Aug 31, 2012 9:23 pm
by abecedarian
Why is it I can search for some arbitrary terms, click on a post, and if I go "back" I get told I cannot use the search function?
Should I wait 30-60 seconds before going back?
Re: "Cannot use Search function"
Posted: Sat Sep 01, 2012 8:08 pm
by kholman
I'm not duplicating/seeing this. Which browser are you using?
Posted: Sat Sep 01, 2012 10:08 pm
by mfro
phpBB (the forum software) has a load-constraint search which temporarily disables itself when the server is on high load or many users use the search function in parallel. That is to avoid lockup if search is used extensively.
That's probably what you're seeing. Some patience should help.
Posted: Mon Sep 03, 2012 11:45 am
by kholman
That could certainly be part of the issue.
There are also load settings set by the admins to limit the number of searches a given user can run without waiting in between. This is to prevent denial of service attacks.
A workaround that I sometimes use is to conduct my search, then open individual links in a new tab or window. This allows my first search to stay open while I check whether a link is useful to me. If I need to go back, I just go back (make that tab open on my screen) to that tab and consult the first search rather than running a new search.
Posted: Mon Sep 03, 2012 11:54 am
by mfro
You can always harness Google if forum search is unavailable. Just add "site:microsquirt.com" to your search term and it will only return what's found over here.
