Slow TPS
nevolution
Slow TPS
Re: Slow TPS
nevolution
Re: Slow TPS
the TPS delay is set to the default of 50, so I don't think that's it.
I was looking at a log from a track day this past weekend and happen to select TPS as I was checking some data. It's flat at near zero for pretty much the whole time, but at one point the TPS fluctuated for a bit, then went back down near zero. I'll grab the tuning laptop tomorrow and upload the log for reference.
Also, I went back and measured the voltage at pin 13 again with someone running the throttle. I'm seeing about .6V closed and 4.6V at wot, which seems reasonable. This is the same microsquirt module that blew a few diodes on an over-voltage or reverse-voltage spike a few weeks ago (Kevin fixed it). I hadn't paid attention to this issue before, so I'm not sure when the TPS stopped working, but I suppose the TPS circuit may have been susceptible to the same spike?
Thanks for your help-
Dave
