Not the usual comms problem
I have got an interesting comms problem which is that I had ms tuner working fine and connected to my bike without any problems and I then tried to change my laptop as my old one was a bit slow. I have been unable to connect to the new laptop and whilst troubleshooting the problem I reconnected the old laptop and discovered that it couldn't connect either and with further investigation i found some damage to the serial cable, it was slightly cut with some copper showing. I have replaced it with a new one but still cannot connect, I have tried portchecker and it can't see the MS but I know that the MS is still working as the bike still start and runs. Could the damaged cable have done something to the MS? what should i be checking next?
Cheers
John
Re: Not the usual comms problem
Could you point me in the right direction for fault finding on the circuit board?
Cheers
John
Its the V2.0 black pcb. I Have an electronics friend who has oscilloscope and all required facilities (his business designs and builds electronic audio equipment inc pcb's and writing software) for circuit board repair but he is usually very busy so it would be good if I can show him what and where need to be checked and what the results should be. I have downloaded the pdf circuit diagram and can see the the section with RX and TX connections but I am a little stuck as to what I do next!
Thanks for all the help so far.
John
I will be dropping it off with my Electronics Dave tomorrow for him to look at.
Cheers
John
My friend inspected the MS and couldn't find and problem with the RS232 chip.
I have refitted it to the bike and the MS works well and the bike even starts and runs reasonably considering I had only put a basic map onto it to before the connection problems started. There is just no connection to computer at all.
The problem started when I discovered that I had left the serial cable attached to the bike and it had got damaged and had probably shorted out (I seem to remember that the ignition had been left on too)
list of what I have checked so far
replaced the serial cable
checked the settings on the laptop/s (I have 3 that can run tuner studio on)
belled out the MS loom from jack plug to ampseal and checked the jackplug too
tried to reload the MS but just get a " no connection" error message
removed the MS for inspection.
Have you got any more suggestions as to what to try?
Are there any UK specialists that can test/ repair MS?
cheers
John
I have the very same problem, almost identical in circumstances. Did you ever find a solution?
Cheers,
Hec
