Injector Fire Timing?
750steve
My original firing order for coils is 1,2,4,3 .............. thing is i don't know when the injectors are supposed to fire (or is it all linked in microsquirt?)
I'll be using 2 crank pickups & a single toothed wheel. The pickups are 180 dedrees apart.
The injectors will be wired in 2 banks of 2 (this is correct, right?), 2 injectors for cyl #1 & #4 then 2 for cyl #2 & #3, they are High Imp injectors.
750steve
Re: Injector Fire Timing?
750steve
Will the 2.920 code lose anything over the 3.8x code? Is there anywhere where i can see what codes have which functions?
From what i've been reading up on the firing i need to set mine to fire each injector twice every 720 degrees. Doesn't this mean then that i need to set my duty cycle to 50%? Is that correct?
So, really it doesn't matter when the injectors fire does it, just as long as it's twice per 720 degrees as the inlet valve only opens once every 720 degrees anyway.
The window is becoming less foggy! lol
If you are already set up for 3.8x I would use it and if it works great. If you are just starting I would use 2.92 and if it works I would consider upgrading, but the critical thing in either case is keeping separate msqs so you can roll back if something doesn't work. The main reason to use 3.8x code is possibly more robust comms especially with wireless tuning. Most of the other 3.8x features are for sequential setups.
750steve
Im currently buying coil leads, i know to get resistor caps (plugs are resistor type too) but what material should the leads be made from & should they be sheilded or suppressed? Basically, what type of lead should i buy? Will uS be affected by interference?
Sorry if that seems off topic, i find it best to ask questions before i try to set it all up
Any EFi controller is tremendously vulnerable to EMI. That said, we touched on this the other day; resistor plugs and caps will do an excellent job of keeping the electronics happy. Matt suggested normal spiral (stranded) copper leads. Basically, the stiff your bike came with!750steve wrote:Im currently buying coil leads, i know to get resistor caps (plugs are resistor type too) but what material should the leads be made from & should they be sheilded or suppressed? Basically, what type of lead should i buy? Will uS be affected by interference?
