Datsun a14
Datsun a14
- Master Squirter
Re: Datsun a14
The engine is a 4 cylinder, so you be running wasted spark with the stock MicroSquirt v3Paton wrote:Hi, I am thinking of running a v3 kit in my datsun 1200 running an a14
Obviously you will need a suitable trigger wheel set up, and throttle body or injection rail plus a few sensors
They're great little boxes, but try reading the manuals, and a lot of questions you have will be answered.... I don't know much about injecting. ...How good are these systems?
No, but you need to wander over to efianalytics and check out TunerStudio, there is a lite version which is free, and the other "pro" version which is about $50...;Do the kits come with programs for tuning on your computer?
There is also some logging software called MegaLogViewer from the same people that is pretty useful too, but this is all a little too much to take in at first.
PS Also slightly confusing there are two firmwares you can use with the v3, the one that is preloaded into the Microsquirt v3, which you can discuss in this forum, manual here and another which you can read about here
Take a look at the MicroSquirt "draft manuals" there, as they will give you an idea of how much you will have to learn, and whether it is for you.
Re: Datsun a14
- Master Squirter
Re: Datsun a14
IMO, your biggest challenge is your knowledge levels at the moment, and the fact you have somebody close by that can help out, even though they sell a different package, is much more relevant to you getting a successful injection project off the ground. Personally, I'd go local this time, and when you've gained more knowledge & expertise, you might want to revisit the MicroSquirts for another project.Paton wrote:....have a dealer for haltech would I be better off running a sprint 500? As they will be able to help out
Good luck
