Microsquirt experts get in here. Canbus ?????
Turbo Kerry
Post by Turbo Kerry »
Would any of you know where I can get the can address for the microsquirt functions. Like
Timing
Coolant temp
Map sensor
Rpm
Charge air temp
I see it has a can high and can low. So I would think all those parameters would have an address and be available on the bus???? I have an ecu that I'm using to control boost and water meth injections, bump box so when boost reaches a set pressure it will bump me in automatic
And also used to log wheel speed and things like that. I would like to grab the microsquirt messages and bring them into my ecu controller. Has anyone done this or know if the messages are broadcast on the bus ?????
Thanks Kerry
Turbo Kerry
Re: Microsquirt experts get in here. Canbus ?????
My system needs a source address for microsquirt an then the bits /bytes of the message
Any help would be greatly appreciated
Kerry
Dan_Austin
Post by Dan_Austin »
More info may be needed to answer your question, specifically the firmware version you are running.
If it is B&G code then the quick answer is that CAN broadcasting is not available and you have to have
a device poll the microsquirt. If you have the MX-Extra code loaded, you will have better luck getting
the address locations from that forum.
