Posted: Wed Mar 05, 2008 3:45 pm
When you are not in bootloader mode, what are you doing with the bootloader wire? It should be not connected to anything, just floating...gun_hawk wrote:I am having a similiar problem.
I tried using port checker to find microsquirt and it did not find the microsquirt. However I notice that I am able to flash the microsquirt with or without the jumper connected . (strange)
I tried flashing it with and without the bootloader jumpered and it reported that 4 files skipped and 1429 records written.
It seems it is in a continous bootloader mode . This might be the reason why I can't connect to the controller.
Help again please
The skipped files message is normal...
One test you can do - connect the bootloader wire to the Vref signal (+5V), this will tie the port high. Then attempt to connect.
When you are not in bootload mode, after reflashing, does the fuel pump output cycle on and off? This indicates the code is running but the code type selection is not selected (microsquirt or MSII, set in MegaTune).
