How to use the stock toothed wheel
Tobisen
Post by Tobisen »
How can I set up the stock toothed wheel on my Suzuki Gsxr 750Srad?
I have tryed to be creative, and made this drawing of the wheel and vr sensor...
This is how it looks wheel engine is on its timing marks!:
Here a pic from my manual:
Image[/i]
old guy
Post by old guy »
I would remove the odd looking tooth on the trigger wheel and set it up as dual spark, single wheel input, 4-1 teeth.
Unfortunately this wheel will not work without modification with the current firmware.
Tobisen
Post by Tobisen »
Simply cut off the tooth?
Will I have to make any other modyfications?
Turn the thoothed wheel on the shaft or something?
old guy
Post by old guy »
Matt
Are you saying that the wheel that he has will not work, or that a 4-1 wheel won't work?
old guy wrote:Matt
The wheel he has will not; a 4-1 will. I hadn't seen your reply when I wrote mine. The settings you posted should work with no further changes other than grinding the tooth off.
old guy
Post by old guy »
What you need to do is to make your trigger wheel look like your drawing that I modified. Your settings in Megatune would be like the msq I posted. This is the default msq, so just pay attention to the ignition settings.
sample.msq
(25.05 KiB) Downloaded 87 times
(15.61 KiB) Downloaded 37 times
Tobisen
Post by Tobisen »
Is the exsmple what you are running with?
I thought that I would have to set the "offset (advance) for output #2 for 180 deg?
When the first thooth is out from the picup cylinder 2 and 3 is in tdc!
If you see at the drawing, the thooth the picup is out from, is tdc from 1 and 4!
the grinded of thooth must be number 4?
Tobisen
Post by Tobisen »
I have grinded of the odd looking theeth, at try to crank it with the settinigs:
4 theeth
1 missing
offset #2: 180deg
Now I have spark:)
But only on ignition output #1!
And it looks like I have 3 sparks on eatch engine rew!
One at eatch thooth!
What is happening here?
old guy
Post by old guy »
Set the offset for #2 to 0 and see what happens. You dont need an offset with skip teeth set at 2,because in your case it fires ign out # 1 at the first tooth after the missing one which counts as 1. The second tooth is count 2, so on the third tooth it fires ign out # 2. Then it see's the missing tooth which tells it to fire on the first tooth and keeps on doing the same thing every cycle.
Just out of curiosity I tried this on my test bench this afternoon and it worked fine.
Also you need to make sure you don't have your vr sensor wires crossed.
I know we are working in two different languages here, so I hope it isn't too hard to understand my explanation.
