PIP signal 5 V instead of 12 V
Ludotech
Post by Ludotech »
Hello,
I have a little problem: my engine is running very good with MS II and the EDIS ignition but the PIP signal isn't 12 V but 5 V!!
My trigger wheel is OK, my Vr sensor is Ok: I think that the problem comes from the EDIS module.
If someone has informations about that, it would be great.
Kind regards
Ludovic
V3 with MS II (blue board),Code v2.35,MT 2.25 + ford EDIS:
Engine: 1300 cc hyundai (G4EH), 4 cylinders, port injection.
zsilinszkyz
Post by zsilinszkyz »
Hi,
With what have you measured the 5v? The PIP is a square wave, it's 12V p-p (unloaded). If you measure it with a multimeter, see 6V (DC) at best.
Check this for more info.
If you use the opto input, it can load the PIP signal so that it will be only 6-8V p-p, depending on the series resistor.
What type of input do you use (opto, VR)?
Zoltan
Ludotech
Post by Ludotech »
I have measured the signal with an electronic scope and i saw that the signal was a square wave of 5 V.
i don't understand, i think I'm going to use another EDIS module to see if the problem is the module.
Thanks.
Ludovic
scirturbo
Post by scirturbo »
Depends if you load the pip signal. Try to measure the signal with nothing connected to it.
SFC
----- Original Message -----
To: megasquirt2@msefi.com (megasquirt2@msefi.com)
Sent: Thursday, June 08, 2006 5:39 PM
Subject: PIP signal 5 V instead of 12 V
Thanks.
Ludovic
This post is at: http://www.msefi.com/viewtopic.php?p=124536#124536
Posted by email.
Ludotech
Post by Ludotech »
Ok, I didn't think that the fact of loading the PIP would decrease the voltage but I'm going to measure the signal with nothing connected.
thanks.
Ludovic
