Looking for close set up......
QuarterHorse
Post by QuarterHorse »
Just seeing if anybody had a similar engine size set up, I'm running spark and fuel, and was wanting a file to get me close to get started.
351 c.i.
Ported box upper ported GT 40 lower
36lb injectors
.520/.560 lift .226/.236 dur. @ .050 114 lobe sep.
Ported GT40 heads
Long tubes full 2 1/2 in exhaust
75mm T/B
MSD
Electric fan
I'm pretty sure that's about the gist of it.
Thanks in advance.
QuarterHorse
Okay how 'bout semi close haha.
QuarterHorse
I know there are few windsor powered 'squirted vehicles out there!
kg6dxn
Post by kg6dxn »
Try this one, can't hurt
383ci, 36lb injector, .484" lift 284 dur. Edelbrock heads, dual 65mm throttle bodies. Worth a shot?
MSnS-e 29q code
MSI V3.0
QuarterHorse
Is there a way I can just look at your VE table? Perhaps fuel enrichments as well? I'm using a different version of megatune than this. Perhaps like a screen print of your VE tables and enrichment would be awsome.
Dustin
QuarterHorse
A screen print say like this, but of the fuel table instead.
chicksdigwagons
Post by chicksdigwagons »
The file he sent, the .vex file, contains the information that you need. Just open it in notepad. If you're still using 8x8 tables you're going to have to do some guestimating to convert his 12x12 down to yours.
QuarterHorse
Well I was using a 12x12 but somthing happend recently that I'm not sure of and now it's 8x8.
kg6dxn
Post by kg6dxn »
I can't figure out how to do a screen print. When I veiw my tale all it will let me do is modify bins or close screen. So how do I do it?
QuarterHorse
I'ts not a problem, I got it off of your file, thanks though!
