What is AutoTune?
peter.blais,
Autotune will stay 'outside the area' if the EGO feedback is not operating, so you have to be in closed loop. That, in turn, depends on things like the coolant temp being above the activation point, the accel not being invoked, the rpm above the rpm activation, etc.
User avatar
conn110
Post by conn110 »
Sorry to be so thick on the Autotune thing. I'm getting the "outside window" message too.
MS 2.2 MT 2.98
My EGO settings on the enrichments page are:
EGO Type: Narrow Band
EGO switch (v): 0.451
Coolant temp activation: 160
Ign. per step: 16
EGO step (%): 1
EGO +- limit %: 15
EGO active above RPM: 1300
If I understand you correctly, I can make sure coolant temp is activating and reduce the active RPM to something lower than my desired idle speed and that should get me into the tuning window. Is that right?
cdallacosta
Post by cdallacosta »
are there any advantadges to using auto tune (besides watching it real time) opposed to MS-II's automatic mixture control set to flash update? are the algorithms the same?
scowman
Post by scowman »
conn110 wrote:Sorry to be so thick on the Autotune thing. I'm getting the "outside window" message too.
MS 2.2 MT 2.98
Ign. per step: 16
EGO step (%): 1
EGO +- limit %: 15
I'm a newbie and no expert, but the custom.ini file has high and low parameters that DO NOT show up in the MSII software GUI.
For instance, you have an active above RPM as well as and ACTIVE BELOW RPM. The latter has to be adjusted in the custom.ini file. Same for MAP. It has an active below in the GUI, but an ACTIVE ABOVE in the custom.ini as well.
The custom.ini is in the mtcfg subdirectory in Car1 in MSII directory.
You can change the parameters there.
I'm not sure how to get this to work with the MSII though. I've found no directions on any of this. Just snippets on the board.
Good luck.
MS-II V-3 Megatune 2.36 Relay Board
1974 Jeep J10
Stock AMC 360 with smog removed
GM TBI with 55# injectors
Duraspark with HEI External Coil and 8 Pin Module
scowman
What is AutoTune?
Post by scowman »
conn110 wrote: Sorry to be so thick on the Autotune thing. I'm getting the "outside window" message too. MS 2.2 MT 2.98 My EGO settings on the enrichments page are: EGO Type: Narrow Band EGO switch (v): 0.451 Coolant temp activation: 160 Ign. per step: 16 EGO step (%): 1 EGO +- limit %: 15 EGO active above RPM: 1300 If I understand you correctly, I can make sure coolant temp is activating and reduce the active RPM to something lower than my desired idle speed and that should get me into the tuning window. Is that right? I'm a newbie and no expert, but the custom.ini file has high and low parameters that DO NOT show up in the MSII software GUI. For instance, you have an active above RPM as well as and ACTIVE BELOW RPM. The latter has to be adjusted in the custom.ini file. Same for MAP. It has an active below in the GUI, but an ACTIVE ABOVE in the custom.ini as well. The custom.ini is in the mtcfg subdirectory in Car1 in MSII directory. You can change the parameters there. I'm not sure how to get this to work with the MSII though. I've found no directions on any of this. Just snippets on the board. Good luck.
MS-II V-3. 1974 Jeep J10 Stock AMC 360 with smog removed GM TBI with 55# injectors GM HEI
-------------------- m2f -------------------- This post is at: http://www.msefi.com/viewtopic.php?p=135554#135554 -------------------- m2f --------------------
Posted by email.
1974 Jeep J10
scowman
What is AutoTune?
Post by scowman »
Posted by email.
1974 Jeep J10
