alternate edis coil packs
cwest
Post by cwest »
As the header suggests does anybody know of a proven alternate that uses a standard type of plug connector at the coil instead of the specific ford one as they are impossible to get here and i need to reconfig my ign leads
TIA
PSIG
Post by PSIG »
Most waste-spark coils will work. I know Chrysler family coils do.
turbo54
Post by turbo54 »
Will the standard two-post GM ones work? Is there any documentation on how to do it you can point me to?
Karl
You can try this
Post by Karl »
Just solder the wires to the coil pack and then put a few thick coats of electrical "tape" paint on it.
tlivingd
Post by tlivingd »
so in using the GM pack just jab something in the slot, for wire one and something in the other slot for wire 2? there is no other connection to these coil packs?
using MS2 V3 board
-nate
455ci Buick Convertible
PSIG
Post by PSIG »
See if this helps: http://www.teglerizer.com/fi/megasquirt ... odule.html
In this case he is firing the coils with VB921's instead of EDIS, but removing the GM guts would be similar.
David
Who is online
Users browsing this forum: No registered users and 40 guests
