Timing map table
BottleFed70
Post by BottleFed70 »
According to the ignition table you posted, you car is not idling at 6*.
Why only 10* timing at the 1200 and 1600 rpm bins below 100kpa? I'd expect your car to run like a dog at lower rpm and throttle.
1970 Ford Mustang
Fastest95PGT
Post by Fastest95PGT »
I was focussing moreso on the boost/upper rpm area for the pinging issue.
1995 Ford Probe GT ~ Megasquirted & Boosted
2003 GSX1300R (Hayabusa)
bens_cab
the car idles perfect
Post by bens_cab »
it idles perfects its only when i put load on at low prms it starts pinging also it holds back slightly that could be mix of both fuel ve and spark ve i just want to try and sort the spark map first before i go to much further
the 6deg idle was on another map it idles ok with 6deg and 10deg the map i posted is the one im using ill get a datalog tommorow and try and show where im getting the pinging
VW Mk1 Golf Gti Cab 20v turbo msns extra 029q2 v3
boost junkie
Post by boost junkie »
http://megasquirt.texasneons.org
My map is at the top. 2.0L turbocharged neon. Should get you close...
-shawn
msns-e controled turbo neon
sample msq's!
