I have noticed on my ICM (02, 2.4) that there is a IC timing control and IC timing control (b). I had the MS-2 setup with the bypass built in. By sitching over to a 95 ICM. I should be able to get my signal from there
and be able to control my timing from my MS-2.
bluetrepidation I have noticed on my ICM (02, 2.4) that there is a IC timing control and IC timing control (b). I had the MS-2 setup with the bypass built in. By sitching over to a 95 ICM. I should be able to get my signal from there and be able to control my timing from my MS-2.
The faster I go, the better I feel.
i know people with saturns that have converted their obd2 systems to use obd1 wiht the MS2. I would assume it could be done on the cav as well. -teb www.turbosaturns.net
Yes get a ICM with a bypass signal input. This is what you want. Did you read the link I posted? All the info you need. Although the link applies to MS I you can easily do it with a MS II setup. If you need further details let me know.
A.J.
V3 PCB
MegaTune 2.25
Innovate LC1 WB O2 Sensor
OBD I Saturn Wasted Spark DIS
w/ Cooling Fan and IAC
