Wideband vs. Narrowband
bronco9588
pommie02
Re: Wideband vs. Narrowband
i bought a techedge unit, they are not cheap...but i bought local in case i had any problems, its worked nowfor six months without any problems. it was easy to set up, and only needs one connection to microsquirt.
try evilbay....with the exchange rate so low, you may get a bargain
bronco9588
pommie02
so yes its best to buy a complete setup, controller and sensor.
you dont need a display, because megatune already has one.
you can buy kits to build yourself...but i cheated and bought one ready built.
i think with narrowband the update rate isnt that quick, so when you are tuning it isnt that accurate
and thet last thing you want is going lean
bronco9588
Andy_Stprbeck
The sensor itself the cheapest place I could find was at amazon.com, shop arround because sometimes the same sensor with just a different lenghth wire can get different prices (+-$15 ish)
For a little more money you can get an innovate LC-1, which seems to come pretty highly reccomended by reading around on the internet, just my impression, your mileage may vary. If you buy the innovate I reccomend DIY autotune.
Andy
See the 8th section:
http://www.innovatemotorsports.com/supp ... Manual.pdf
Geoff
