M-0 Wheel
M-0 Wheel
I posted here once before about trying to get a Yamaha Phazer engine setup. It's an odd fire 2 cylinder 4 stroke. It has a wheel on the crank with 12 teeth (no missing), with a VR sensor on it. The cam has a Hall sensor on it, and there is one recessed tooth in it (It goes down, not up).
We've been working on trying to get spark for the last 6 weeks. We've trouble shot everything we know to do. Our problem is that under M-0 wheel settings for dual spark we get nothing. No triggers and no tach signals. Last night we were able to get tach signals using "Single Crank Wheel" under dual spark options. The timing between the spark events is correct, and the RPM is accurate, so that felt pretty good. We were also able to set it up using "Single Cam Wheel" under dual spark options, so it appears that both sensors are providing usable signals. Under "dual inputs with cam sync" we had one coil being driven by the crank wheel and the other by the cam wheel, as expected. So we felt pretty good about that.
When we tried to set it up under M-0 with Rising Edge, we were unable to receive even one trigger or tach pulse. Everything went dead. We tried using falling edge, no luck, we tried playing with the tolerances, we tried manipulating the numbers in the "number of skip teeth" and number of teeth on the wheel, and it didn't change anything.
So I guess my questions are specifically about the M-0 wheel setup. Has anyone here successfully setup an engine using the M-0 wheel? If so, what did you do? There must be something we are missing. Last night we spent 18 hours trying to figure it out, had no luck. Any help is greatly appreciated.
Kyle
Re: M-0 Wheel
Use 'falling or rising cam sync with tach or wheel' (depending on your cam input polarity) dual spark option and be sure to setup the crank sensor polarity correctly as well. Also make sure that the cam input occurs between the declared tach tooth and the previous tooth every time it changes state on the configured edge. Hope this is of some help to you.
Re: M-0 Wheel
How do you define what is the declared tach tooth? Is that simply the tach tooth that occurs immediately after the "configured edge", which is just the rising/falling edge of the cam signal? How do you actually determine what
I've attached a picture of the signal we are seeing from our cam and crank sensor on the oscilloscope. How should we set it up with these signals?
Thanks for the help!
- Attachments
- (148.81 KiB) Downloaded 34 times
Re: M-0 Wheel
Sorry about that! I just re-read my post and it even confused me. The tach tooth is the first tooth after the cam sync input occurs,or it can be a tooth declared by using a number of delay teeth depending on your physical setup. Regardless of whether you are using delay teeth or not, the cam sync must occur between the same two teeth every time otherwise you will get a resync and this will make it impossible for the engine to rev past that point.
Your signals look good and with a 12 tooth wheel it is plain to see that you have plenty of time to fit the cam signal in between the required two teeth. If it is possible you might want to make some adjustment to centre the the cam signal between the two teeth just to allow for cam chain stretch or mal adjustment. Your scope picture tells me that your MT configuration would be rising edge for the VR input with a rising cam sync. Now get the spark output polarity right and you are laughing. Best of luck.
Paul
Re: M-0 Wheel
Thanks for clearing that up.We set it up as you recommended. It still doesn't give us any tach signals. We aren't able to adjust anything with the VR sensor to account for any chain stretch, but it looks like there is enough room that it *probably* won't be a problem...
We set up MT with a rising edge for the VR and a rising cam sync. We ran it like this- no luck. every 5 seconds of cranking we'd get a single tach trigger. I played with tolerances a little, and was able to get a tach pulse every 1 second of cranking or so, but I never got two consecutive pulses.
Does this mean that it sees an error every other full revolution, so it starts over? Or what does that mean? I can send you the MSQ file if you'd like to take a look at our setup.
Thanks for all the help paul, we're getting closer!!
Kyle
Re: M-0 Wheel
Yes, please post your current MSQ and also a datalog of your cranking attempts (if you can get one). Also post all other relevent info such as ECU type, software version and engine configuration including firing angles. This gives everyone reading this thread a chance to analyze your problem and hopefully contribute some helpful advice.
Paul
Re: M-0 Wheel
Here is what we've got from the Megatune. I'm going to try to do some data logging tomorrow, so I'll post that if I can figure it out.
The engine we are running is a twin cylinder 4-stroke, 180 degree odd-firing engine with a 12-tooth wheel with zero missing teeth. There is one tooth on the cam.
Take a look at our file if you can, and let me know what you think of it.
I've posted a picture in another post in this thread of the signal we are getting on the oscilloscope. Help is appreciated!!!
More to come,
Kyle
- Attachments
- megasquirt200811252139.msq
- (25.17 KiB) Downloaded 59 times
Re: M-0 Wheel
Re: M-0 Wheel
I'll check and see if I grabbed the wrong file. Thanks for the heads up.
