Dual Spark Setup for Model Year 2000 Harley EFI Twin Cam
mikestiffler
Has anybody been able to set up the Dual Spark portion of the Microsquirt controller for a Harley model year 2000 or newer?
I've read the Dual Spark section of the Microsquirt manual several times and the 2.C example is the closet example of what I have. I do know that the Harley has a 32-2 tooth crank wheel and a cam sensor for phasing.
Unfortunately, I don't know what the correct number of teeth settings would be for Skipped Teeth and Delay Teeth because I don’t know the physical relationship between TDC of cylinder one (is that the cylinder closest to the front wheel?), cam sensor, and the two missing teeth on the crank.
Also, how would I check the timing with a timing light to set trigger offset? With the motorcycle set up originally as a fuel injection model there aren’t any timing marks to reference.
Any help will be greatly appreciated.
Sincerely,
Mike Stiffler
Re: Dual Spark Setup for Model Year 2000 Harley EFI Twin Cam
As far as the timing between cam, crank it is only necessary for the cam signal to come in sometime before the missing tooth on the compression stroke of cylinder 1. However, you must determine the timing between TDC #1 compression and the missing tooth. This is called degreeing the engine. If nothing else you can hold your finger over the spark hole of #1 and feel the pressure on the compression stroke and see or feel the piston coming up. But this is very crude and I would degree it properly so I could use a timing light.
mikestiffler
I've attached a 32-2 timing chart for the Harley and wanted to review my Microsquirt settings:
Trigger Wheel Teeth (M) is 32
Missing Teeth (N) is 2
Skip Teeth is 32
Delay Teeth based on chart is 9
Dual Output trigger offset is -45 degrees (315 minus 360)
Based on the attached timing chart do you agree with the Delay Teeth of 9?
Do you agree that the trigger offset of negative 45 degrees is correct?
Thank you,
Mike Stiffler
In setting this up you have to assume cylinder 2 is even fire so make a copy and mark where cylinder 2 TDC comp would be if it were an even fire engine. From your diagram it would coincide with cyl 1 TDC EXH. But if you add 4 teeth worth of advance (45 in degrees) that will give you the same actual advance as cylinder 1 gets. So you need to set the #2 output offset to +45 deg, plus angles always being advance/ BTDC.
mikestiffler
"But for Dual Spark, because it is too complicated and there is not enough RAM or CPU time, you must start and finish both dwell and spark within the time between 2 consecutive tach pulses. In this case we always want to use the negative y degrees, or else the math ends up coming out incorrect in the code."
mikestiffler
If there was any reference to ign3 in the manual it is either a typo or cyl 3 was meant. There is no ign3 output in microsquirt.
I know this is difficult to understand. On our plate is the writing of a program that will display a wheel and let you place the crank and cam sensors where you want them and the program will figure out the settings for you. However, there are, even for 1 and 2 cylinders, a lot of options - you have 2 and 4 stroke, wasted/ sequential, even/ odd fire, and each possibility for no. cylinders has its own quirks. It's not an easy thing to do and will take time.
