Code to fix offset/delay teeth
Moderators: grippo2, Bruce Bowling, grippo
robh
Re: Code to fix offset/delay teeth
Post by robh »
DME pin 27.
robh
Post by robh »
vrin1(+) is DME pin 27 and vrin2(+) is DME 26.
I connected both vrin1(-) and vrin2(-) (DME pins 8,25) to the Microsquirt pin 33.
Peter Florance
Post by Peter Florance »
robh wrote:vrin1(+) is DME pin 27 and vrin2(+) is DME 26.
That's pin 2 on the VR sensor; I'll check the waveform tomorrow to determine the correct edge. I think that's more important than stim testing
Peter Florance
Sorry, finally got time to sit down and scope pin 2 of Reference Sensor on my test wheel
(20.46 KiB) Not downloaded yet
To me it looks like rising edge is correct, assuming:
1) Pin 2 of VR sensor is connect to VR +
2) Microsquirt VR does not invert (I'm 99% sure of this)
Peter Florance
Peter Florance wrote:Sorry, finally got time to sit down and scope pin 2 of Reference Sensor on my test wheel
I said MicroSquirt, but of course I meant Sequencer.
robh
Post by robh »
Thanks for taking time to record the waveform.
Strange thing is the car runs much more stable with Falling Edge and I am using a Microsquirt. I assume Microsquirt VR inversion would be same as Sequencer.
I have probably about 3 hours of driving time with the Falling Edge setting now and I have not yet experienced a resynch. Could this because it changed the phasing of the crank speed sensor w.r.t. the reference sensor?
Peter Florance
robh wrote:Thanks for taking time to record the waveform.
I'll test the Sequencer input and see what it does.
Peter Florance
Rob
Can you verify which pin of your sensors are connected to VR+ inputs?
Thanks!
robh
Post by robh »
Sorry I've been away visiting family for the holiday.
I will check into this as soon as I have a chance. I'll do a point to point check from the Microsquirt AMPseal connector to the 3-pin VR sensor connectors.
Peter Florance
robh wrote:Sorry I've been away visiting family for the holiday.
Thanks Rob,
Once you know, I check with VR sensor at that polarity
