Reset Issues
Reset Issues
Re: Reset Issues
Re: Reset Issues
The ms gets its power from it's own main relay right off the battery, which feeds a 15A car audio power filter, then feeds the 2A fuse, which connects to the ms. FYI, I have also upgraded the alternator, which is capable of maintaining a system charge of up to 40A, the old system was only capable of 26A, this didn't make any difference in the restarts either. I used the TachRef program to setup my gap and signal strength checks during cranking, there was no noise found during that process. I appreciate you taking the time to help, thank you, Paul
Re: Reset Issues
Any spark plug wires run near wires to and from the MicroSquirt?
Another possibility that came to mind is non-resistor plugs. These tend to cause noise issues.
