Serial cable wiring???
triangles95
Re: Serial cable wiring???
MicroSquirt controllers normally come with the serial cable fully assembled, so there's no need for people to wire or re-wire them. Just plug the mini-stereo connector into the supplied harness, and the DB9 connector into the computer (or serial-USB adapter).
However, if you want to make/modify a serial cable, the MicroSquirt cable is the same as the GPIO cable, and there's instructions for that in step #1 here: http://www.msgpio.com/manuals/mshift/gpconnect.htm. Just be aware that the ampseal pin assignments for Tx, Rx and GND may not be the same as a GPIO board.
triangles95
triangles95
