Injectors won't close of priming
Tommy
Inj 1 permenantly on
This is a problem that has recently arrived. I was running fine previously.
Tommy
Re: Injectors won't close of priming
Thanks for the response. Since my last post(s) I rewired the injectors so that they all (4) worked off pin 10 and I was really pleased when the engine started and seemed to run OK. However on the second run I found that the same symptom has now afflicted pin 10 and all the injectors are open all the time there is power to the ECU. I tried re-setting to the previous restore point but no luck.
In answer to your question I can measure no resistance between pin 9 or 10 on the microsquirt with the plug removed and ground. I had originally thought there might be a ground on the wiring to the injectors but there is no circuit there either. It makes me wonder whether I have a hardware problem in the microsquirt, if so I need to know what is causing it.
many thanks
Tom
Brain not engaged due to onset of Christmas! Previous measurements made to vehicle ground which of course is not connected with plug removed! Pin9 to pin 23 =76 ohms pin, 10 to pin 23 =23 ohms.
Tom
happy New Year
Tom
