What about the through hole size for the boss on the intake manifold side? 10mm also?eric at wryday.com wrote:
I drill a 10 mm through hole, ream it to appropriate depth with a 13.5 mm
reamer, chamfer it about 1.5 mm with a 40-45 degree countersink, then
give it a little more bellmouth with a 15 degree countersink.
mounting injectors to a fuel rail
panel
witha torch i heated the bungs until the silver solder melted out. plugged the holes with 1/4" rod and silver soldered those in, then drilled holes in the appropriate spot and silver soldered the bungs where i needed them.
to be honest i didn't silver solder them myself. i hear its kinda tricky. this was on a round rail too which made it trickier but all worked out well.
james
panel
Whats the thickness of this material so as not to drill the through hole into the injector pocket? What size is the through hole and also what is the size of NPT on the end? 1/4"? Which hole is 10mm? The inj through hole or the hole through the whole thing?eric at wryday.com wrote:
efahl
- Site Admin
> [/quote:2b42cb0473]
I'm not quite following you. The through-hole is the first thing
that I drilled to define the injector pocket, the reamer and c-sinks
just make it fit. Tom has dimensions of the extrusion on his website,
does this help?
<http://www.rossmachineracing.com/extrusion.html>
3/8" but you shouldn't use NPT, use straight AN with o-ring seals.
I think the hole is the right size for 5/8"-18 fittings already.
Eric
Eric, you said the above in an earlier post. Does this mean I don't have to mount and weld a boss into the rail? I can just drill to these dimensions and the injector will just push in to the rail?
Will the inject stay in the rail ok? Will I not need any clips to hold it in place?
I've just bought some 37lb high impedance lucas/delphi injectors from Racetronix (great price
Hi I'm new to these boards, sorry for all the question but your help would be much appreciated.
Regards
Dave
efahl
- Site Admin
Re: mounting injectors to a fuel rail
Dave,
That's correct, no welding because the rail is extruded to have enough
meat to allow just this. Here is Keith's page with the pix I took of the
stock and a brand new one with the tools that I used, click the thumbnails
for the big version:
http://not2fast.com/audi/5ktqa/ms-2004/ericPics/
http://not2fast.com/audi/5ktqa/ms-2004/ ... uction.jpg
On my car I have clips, plus the rail is bolted to the head. On Keith's
we just bolted the rail to the head with some 1/8" stainless brackets I
fabbed up:
http://not2fast.com/audi/5ktqa/ms-2004/ ... racket.jpg
Most likely, but you'll need to do some cursory measurements to make sure.
Just make sure the end of the injector is about 14 mm diameter at the o-ring
and that the end containing the o-ring is about 10 mm long. This makes
it a "Bosch form-factor injector", which should work just fine.
Eric
Dennis
Where can you get a 13.5mm reamer? I looked at grizzley tools and they don't carry a 13.5mm reamer.
Pardon my ignorance but I assume I can just chuck a reamer up in my drill press or in a chuck in my lathe to ream a fuel injector pocket? Will a reamer handle reaming mild steel? I saw grizzley tools carries a couple sets of adjustable reamers. Not having used a reamer before I assume I could purchase an adjustable reamer set and adjust one to exactly 13.5mm or .540" is this correct?
Thank you for the help!
