mechanical pump for EFI use
ChevelleFan
Post by ChevelleFan »
I got this link from a friend and it looked kind of interesting.. looks like it's only for small-block chevy at this point, but the concept seems simple enough.
http://www.racepumps.com/tech.html
-Dave
'70 Chevelle, MS-II/406 Stealth Ram/TH350/3.55
My success story
12.94 @ 106
BottleFed70
Post by BottleFed70 »
Sure would amke things alot easier for those of us doing an EFI conversion!
Wonder what they want for one of them?
1970 Ford Mustang
ChevelleFan
I went to the ordering page for a FI small-block -- $299 :shock:
The model for a carb was only $20 cheaper.
Interesting, but pricey.
-Dave
My success story
12.94 @ 106
OneSlow73
Post by OneSlow73 »
for higher hp motors(800+) you really cant beat this pump assuming its all its cracked up to be. a decent electric pump good to 800hp for a carb is at least 4-500$, whereas a efi pump would cost even more and BIG electric pumps arent good for street use, they tend to burn up....
1973 malibu. 468 FAST efi.
andereck
Post by andereck »
This is Howard Stewart's pump and I think you should call them and ask if its been used on port efi yet. Its still kinda in development. It was developed for Busch/Cup racing. (carburetors) A performance inline electric pump isn't that expensive and is designed to make volume at higher pressure. The Stewart pump will make up to 60 psi deadheaded, but no volume up there. His idea of a bypass regulator is a dead head regulator with a jet in one of the outlets. That isn't a true return regulator system and it won't be able to maintain consistent fuel pressure over the wide demand range of efi.
Keep in mind while cranking the engine might only be turning 250 rpm or so and the camshaft turns half that. Its tough to make volume and consequently pressure at that low of an rpm.
Just my .02
OneSlow73
Post by OneSlow73 »
i have this pump running now on my 468bbc with FAST seq efi. it takes longer to start because my fuel rails bleed down overnight but once its started it works good. ive spun the motor to 7000rpm making about 750hp and it held 50psi pretty solidly.
