Well, if you read the manual... Oh, yeah, there isn't one. Anyhow, it would say something to that effect:whittlebeast wrote:Is that possible that that is the correct answer. Or is that a missfire feading raw fuel into the exhaust confusing the 02 ....
Beware that if you go so rich that the spark is blown out, the lambda sensor will read the unburned mixture as dead lean (what with all that oxygen still present) and the closed loop algorithm will attempt to add fuel, which the autotune algorithm will detect and adjust the VE bin richer, thus making a bad situation worse. Use with caution, this thing will not perform magic. (I'm not even convinced it will do anything useful.
Eric
