Q about STUFFING VELOCITY STACKS
Secondly<<<I plan on shooting the secondary injectors directly down into the tops of the stacks. would I have to worry about fuel puddling in the plenum? This is MSII, first batch.
Does MSII even do secondary injection? I didn't even think about it until just now!
75 Cosworth Vega turbo (MSII with EDIS)
88 Toyota Pickup, Auto(modified valve body), 22re 4cyl, controlling fuel and VAST stock ignitor with MSnS 024s9
1968 Electric Subaru Sambar 360 VAN
'92 Biodiesel Jetta
old-colt
If your stacks have a full radius they will have no problem pulling air from behind them. If they only flair out partially they would be best if the floor of the plenum was flush to there opening.
I have built both styles.
Spraying the secondaries down the throat should not be a problem since they will only be active at high airflow rates. You want to insure your design will have minimal crossflow over the top of the stacks to reduce blowing the fuel over to another cylinder. I am currently building an intake with individual water spray down each stack.
Charlie,
If it ain't broke, Modify it!
http://ffmsd.com/
http://www.cardomain.com/ID/old-colt
I was also planning on water injectors at one point. Can you use regular fuel injectors for this? how about cold start injectors?
How does water spraying affect the fuel required for a given power level?
I have a set of 8 42lb/hour injectors I was planning on using, 4 for primary, four for secondary. If I get rid of the secondary set, and replace them with water injectors, what kind of power could I make? 300+ with a good setup on a 2 liter 4? I know the 4 42 pounders could make almost 300 Nat Asp, but how does water injection affect this?
Thanks for the reply, I have been mulling this over for months.
Tony
'92 Biodiesel Jetta
old-colt
You may be best off changing to a set of 550s for the power level you are aiming for, they will get you into the mid to upper 300hp.
Fuel injectors for water spray are prone to be short lived since they are not really happy with either water or the alcohols in the mix. They are used in race conditions but are considered a consumable device and they do not intend them to work after sitting between events. I have heard rumors of injectors with stainless internals but have no honest knowledge of them. Maybe someone can chime in on the truth to that fact. There are also some regulators with water resistant internals out there.
I am using Misting nozzles for my setup. There are some other threads covering the affects on mixture and timing elsewhere on the forum. It is well documented of pushing boost up around 30psi on pump gas though.
Here are a few intakes I have done. Granted these are done in alloy so the build is a bit different than yours.
Charlie,
http://ffmsd.com/
'92 Biodiesel Jetta
old-colt
The intake that has the flush floor is an ITB set for Mitsubishi 2 litre, it varys from 1 1/2 to 2 1/4 above the stacks, this one has the water spray in it.
And this pic with the full radius stacks are a set of Busa throttles going on a Starion, this one has about 1 1/2 above the stacks and the floor is at the seam of the stacks to there adaptors to the TBs. I am surprised I do not have a pic of this one with the plenum on it.
This one also has water spray nozzles over the stacks.
Hmm, the pic does not show, I must have exceeded a limit in posting.
Charlie,
http://ffmsd.com/
Thanks for the help so far, I sent you a private message, so if you don't mind, I'd like to see some more of your work!
Tony
'92 Biodiesel Jetta
I ask because on my 6 cylindar I don't really have room to keep the stacks far enough apart to keep them from hitting each other. So, I'd like to stagger them like you did if it won't cause a problem.
thanks
allen
old-colt
There are a couple of ways to get around the spacing issue.
In the case of that photo the stagger was done to provide a broader power band. The original Hayabusa has a similar stagger as well as differant ignition timing between pairs of cylinders to work with this. This setup has 1&4 short and 2&3 tall.
If you download the pic from my second post with the full radius horns, those as well as the ones in the first pic have the top of the stacks ground to allow the spacing to be closed up.
Charlie,
http://ffmsd.com/
