Page 3 of 3
Re: Trigger wheel phasing
Posted: Tue Jul 07, 2009 10:32 am
by SQLGUY
Calculated should be fine as long as you have a first column of your table that's a ways below idle. Use the square that the cursor is sitting in when not running, and the one below it, to set cranking advance.
Posted: Tue Jul 07, 2009 7:36 pm
by Aaron Silidker
Cool..
I will phase the wheel such that I have my tach tooth 10-12 degrees BTDC and use the offset to try either calculated or trigger rise starting and see what works best.
Posted: Tue Jul 07, 2009 7:42 pm
by Aaron Silidker
And now I also see where having a wheel with lots o teeth gives you a big advantage in starting with respect to being able to just change the tach tooth and then adjust with offset if doing trigger rise. I couldn't do more than 30 or the gaps and teeth weren't similar size/the top of the tooth was smaller than the width of the sensor tip.
