Here is a photo. I had it wire EDM'd at school for free.
Anyhow, I am getting conflicting info on how to time the wheel to the flywheel. One friend who works for bosch motorsport says to put the leading edge of the gap about 70 degrees btdc so there is less room for error because the computer will synch to the gap and then fire the spark soon afterward (max advance is around 50, so 70 is safe).
But for startup on a single I assume I want trigger return since RPM is all over the place...which means I want the gap 12 degrees BTDC or so. This presents an issue however because spark might occur in the gap correct? And I will have nearly a full 360 degrees of revolution of the wheel sometimes before firing spark after the gap which leaves a lot of room for synch error I assume.
Let me know your thoughts so I can get the ring pressed on and try to get the bike all wired up.
