Things you need:
wine (I used 0.9.5, as thats the most current release) running on gentoo linux. though your distribution shouldn't matter. Older versions of wine make work as well, but your mileage may vary.
winetools http://www.von-thadden.de/Joachim/WineTools/
Once wine is installed it's recommend that if you had a previous wine installation that you either back it up or erase it, by removing ~/.wine (rm -rf ~/.wine ) and then running winetool via "wt" from a terminal. It will prompt you and potentially warn you about whatever, justclick through.
You need to use winetools (wt) to install a handful of core windows stuff so that megatune and any other windows apps you want to run will work.
Within winetool, select the top choice, "Base Setup", and install The Truetype font Arial, DCOM98, Micrsoft foundation classes 4.x and IE 6.0 (even if you don't plan on using it) as many other future apps have a dependancy on IE.
After those are done choose: "Basic Windows System Software" and install Windows Installer, Visual C++ runtime, MDAC 2.8 and Jet 4.0 SP8, MSXML 4.0 sp2 and common controls 5.0
Finally, go back to the main menu and select the Microsoft Truetype Fonts and install all of them in turn.
Once done, exit from winetool and download the megatune setup exe file and from a terminal run "wine mt225bXXX_setup.exe" replace XXX with the version you downloaded. It should install nicely and even create a desktop icon. (I get three icons, one of which was bogus so I just delete that) Note in each case of installing megatune, wine crashed at the end (bug) but it's harmless. From there it runs and "just works" NOTE: this requires your linux box to have a regular serial port so far. I haven't tried to get it to work via my usb-serial adapter yet...
NOTE: if it fails to create an icon (it might if you have a different desktop setup than I) you can run the megatune EXE directly running
Code: Select all
wine ~/.wine/c/Program Files/MegaSquirt/MegaTune/MegaTune2.25b{version}/megatune.exeEnjoy...
