Injector port type
Posted: Sun Apr 09, 2006 6:38 am
by Volkkarijermu
What's is the difference between "Port" and "Throttle body". What MS does when "Port" selected and what when "Throttle body" is selected?
Posted: Sun Apr 09, 2006 6:51 am
by the bubbler
I suggest you have a read through the megamanual, as this is all covered in that.
Basically port injection tends to feature an injector per cylinder, usually pointed directly at the inlet valve.
Throttle body injection tend to feature a single large injector, mounted further up stream, and acts more like a well tuned carb than port injection.
Posted: Sun Apr 09, 2006 6:57 am
by Mike_Robert
The code doesn't do anything different. The full explanation is here:
http://msefi.com/viewtopic.php?p=109348 ... ody#109348
-Mike
