Sidney
750 XTZ bike... What TB's?
Sidney
I'll see if I can answer your questions.
For the throttle bodies, you need to measure your caburators. You need to know their diameter and the distance between them. Once you know that, take a look here http://www.msefi.com/viewtopic.php?t=6627 and see if anything looke like it might fit.
Sensors. You need an air temperature sensor to go in the intake. You need a coolant temperature sensor if you rbike is water cooled. If it's air cooled, then you need an oil temperature sensor or a cylinder head temperature sensor. And lastly, you will need an oxygen sensor.
MS Will work on a motorcycle.
I hope this helps you out.
Fred
