I sent you a PM, so you know this much - but if you haven't already got a holley tb, I wouldn't really recommend it... I had all kinds of injector problems with mine... then they stopped manufacturing the injectors and replacing them would have cost nearly $500 (would have had to buy 4 new style injectors at $80 then the new style tower assembly at $120). I'm sure there are those who had good luck with the thing, but I'm DEFINITELY not one of them.
Having said that, with the injectors out, it's making a fine 'empty' throttle body for my port setup
I know Lance used (maybe still does?) the same way, as an empty throttle body. I don't know if he actually had trouble with it too, or if he just decided to switch to port injection.
Have you looked into the cost/work difference in doing port injection? My 440 needed custom work done to the manifold (nobody sells a 440 port injection manifold yet, though edelbrock makes one for their kit), but even with that I was surprised at how easy it was to setup, and it really wasn't much more expensive either.
