O2 Sensor Problem
Chrisfol82
O2 Sensor Problem
But when i hook up my voltmeter to my O2 sensor i get values up to about .56. Shouldnt i be getting the same reading off my voltmeter that i am megatune.
No matter what though i cant get a reading above about .56 though even if i richer it up so much it will barely run. So i know somethin must not be right with my O2 sensor. Which is understandable since it is about 20 years old.
But i was thinking about getting a wideband and i didnt want to get one right away if there might be a problem with the computer rather than just with the O2 sensor itself.
This is a known issue with some MS-II codes. To fix it, 'calibrate the AFR table' (under tools) to DIY-WB. Click OK, and let the 1024 values burn. Then shut off MegaTune, cycle the power to MegaSquirt, and restart MegaTune. Go to 'calibrate the AFR table', and set it to narrow band, then click okay, and let the 1024 values burn.
After that, it should read correctly at all times. You won't have to do this again unless you burn new code to the controller.
Chrisfol82
