Tuning idle (bins) question
Could someone tell me what's the trick in setting them up?
My idle should 850 - 950 rpms
thanks guys
(this is a general question, despite running the extra code it's a Microsquirt. Don't move this post as it has nothing to do with the code)
SQLGUY
- Experienced Squirter
Re: Tuning idle (bins) question
Set second column at idle RPM
Set first column maybe 100 - 200 below idle RPM so you can set that column a bit richer than idle in case the engine starts to stall. This also gives you a good place to calibrate your startup "landing" point in the upper left (where you'll initialliy hit when starting).
I'm not sure if this is what you're looking for, nor if this is ideal, but it's what I'm using now, and it's working OK.
Cheers,
Paul
