sequencer testing round 2
ca434sbc4
Post by ca434sbc4 »
Back at testing the sequencer again, currently running just the ignition - with fuel being provided via the existing MS2.
Noise issues found/resolved
- adding a 2K pullup on the red bootloader input to Vcc and removing the bootloader wire from the ampseal cleaned up the Vcc noise.
- the Vref has about 400mV noise on it with the engine running and the sensor connections not connected but well removed from any noise source - basically hanging off the outside of the fender. I'll work this tonight.
TheMonkey
Re: sequencer testing round 2
Post by TheMonkey »
Hey Marc, glad to see you're back on the case.
how is it that the VREF and vcc noise is 2 different issues? i guess i don't fully understand the difference between the 2.
interesting that you are doing ignition only first. when i was running both, i found that the fuel pulses looked great, but the ignition pulses were the problem items (prob because fuel pulses are grounding, and ign is 5v; either vcc or VREF?)
