Ampseal part number
Ampseal part number
http://www.mouser.com/ProductDetail/Tyc ... mK4DsR4qig
Is this the right one? Also, do I only need the terminals when I order the plug, or will it be missing seals or anything else?
thx
Re: Ampseal part number
racingmini_mtl
Jean
Peter Florance
I assume you'll need contacts. Do you have tooling for it?TheMonkey wrote:I need to get an Ampseal plug for injector/coil side of sequencer. Mouser has a few 35 pin plugs, and it's not clear the differences, but only one is in stock and available. It's Mouser part number 571-776164-4, mfgr part number 776164-4.
thx
That might be worth considering using different colors at each end of the Sequencer on production units. Put a black connector on the main end (which is almost the same pinout as a normal Microsquirt) and a different colored connector on the other end so you can't accidentally plug it up backwards (which I managed to do with one prototype).
I already ordered the gray one, I guess I'll do some modification to make it fit.
Peter- Yeah, I got the crimpers and bunch of pins when I did the BMW unit. I think I read that they were hard to work with, but mine assembled really nicely.
Peter Florance
+1 on different connectorsTheMonkey wrote:I agree with Matt on different fits for either end.
Did you get your tooling from Mouser? What part #'s did you end up getting?
Thanks!
BTW email notifications appear to be broken from this site again.
pins i used are pn 571-770520-1
the crimpers i got, i *think* i got them from Mouser, but all the little Mouser boxes I see in my stash (with the invoices in them) are the small variety that they wouldn't fit in. I looked at the crimpers i have, there is not a number stamped in them. blue handles, and i'm certain i spent < $30 on them. i soldered all the connections too - sort of belt and suspenders approach.
Peter Florance
Ah so these are not the official AMP seal crimpers. I suspected that many open barrel crimpers would do the job well enough. I have several lying around. I think I'll get some pins and have a contest between them.TheMonkey wrote:Peter-
Thanks!
