rich in one gear, lean in another, same fuel bins
gvanhorn
Post by gvanhorn »
Been working at this for a week, hard pull from 2k rpm in 2nd, and motor is rich (10:1), shift to 3ed and motor go's lean, all this is in the same fuel map bins. msq attached, log will be in next post. injectors are 65lbs/hr low Z (2.5 ohms).
CurrentTune.msq
(26.06 KiB) Downloaded 65 times
gvanhorn
Re: rich in one gear, lean in another, same fuel bins
Post by gvanhorn »
here is log file
run6.msl
(1.05 MiB) Downloaded 86 times
You have a very sharp drop-off in fueling from 145 to 150 kPa. This is going to make fueling at full boost very touchy as a tiny change in MAP has a huge change in fuel. I'd try smoothing out these rows. Or better yet, rescale your kPa bins so they're not packed so close together under full boost.
