So when I am grounding things, for example the MAP. Do I ground the MAP to a body ground then the sensor ground wire to that same location? Or do I just splice the MAP ground into the sensor ground and let the Microsquirt handle the grounding. I am having difficulty understanding how the whole grounding using the sensor ground works.
Also I am attempting to run a inline 6 M20 bmw motor on Microsquirt. Just before I ordered the Microsquirt I had found documentation that Microsquirt can run a 6 cylinder with EDIS6. So I purchased the EDIS6 and the Microsquirt. Just after that purchase my laptop crashed and I am now on a new PC. So all my bookmarks are gone. Can anyone point me to the docs to wire up EDIS6 and Microsquirt.
Last question I swear. If you stuck around this long then thank you
I remember when I first started looking into MS years ago there was a LCD display called Megaview. Is this no longer a thing? anyone have any suggestions for a DIY racedash or at least a small LCD display to show important MS info while driving.
Thanks so much and I really hope to add to the community after my mandatory learning curve time.
Joe
