Calibrating ratiometric pressure sensors with fault tolerance
GrocMax
Post by GrocMax »
Forum search function is broken, spits out every relevant term in the search field as being 'too common'.
How do you properly calibrate (including fault parameters) ratiometric pressure sensors when you can't change the voltage field where 0 pressure and max pressure reside?
The help file math function does not work when you divide or multiply by zero. I get it, but others may not. May want to append this.
How are faults determined for 0v-5v sensors?
If you use a 0.5v-4.5v ratiometric sensor will it ever go into fault if above 4.5v or below 0.5v?
