Injector resistor selection?
'96 VW GTI VR6
MegaScott
- MegaSquirt Guru
Resister size?
http://www.megasquirt.info/manual/minj.htm#injresist
maybe also here-
http://www.msefi.com/viewtopic.php?t=3266
Basically make sure your TPS settings aren't putting you into flood clear mode.
S.
Same question for me. Is the V3 require the resistors?tlivingd wrote:The manual refrences MS-1 v2.2 main board.
does V3 requre resistors for the injectors? the V3 has a flyback design to it. I do not see this refrenced in the manual or the assembly instructions of the v3 board.
any help would be appricated.
-nate
I am running 4 - 55 lb Siemens (2.35 ohm) ?
Thank you.
My Success Story
- use PWM and the flyback circuit (a separate board for V2.2, built in for V3 main boards). or
- use resistors. The calculation is the same for V2.2 and V3 boards, as Scott says, use the calculator here: http://www.megasquirt.info/manual/minj.htm#injresist
Resistor calculation is not an exact science, though, and if the car won't start with the specified resistors, you may have to lower the resistance about 15% to 25%.
