LPG and Petrol
Cooke
LPG and Petrol
I want to know, could megasquirt be used to run both the petrol + ignition and the lpg + Ignition?
Use msns-e , with patrol on table 1/3 and lpg on table 2 .
Use the table switching feature to switch between two fuels .
And you'll need an extra relay to cut power from inj bank two
when running on petrol .
I've been running this setup for over a year now .
Switching between fuels can be done "on the fly " without the engine even noticing it . No bumps , stalls ets c .
The only issue is that starting a cold engine on lpg is a problem , because megasuirt doesn't do lpg temp/pressure corrections .
But even in winter , I had to run the car on petrol for only a minute or two
before i could switch to lpg .
Pat
