surge tanks?
sclay115
surge tanks?
Post by sclay115 »
i'm looking to convert my triple weber'd 240z to an injected motor...and i've seen diagrams online using the stock fuel tank with a low pressure pump that loads up a small aluminum tank that then has a high pressure pump that moves fuel to the rail, and then the return line that sends fuel back to the tank, but not the gas tank, the surge tank. but here is a diagram of what i'm talking about, as i'm sure it's confusing, me trying to explain it...but is this a viable option for a conversion? or should i just get new fittings on my tank brazed on, or get a cell...or what do you think...?
http://www.sdsefi.com/techsurge.htm
steve
elansprint
Post by elansprint »
Steve if the car is injected from new there is usually a swirl pot incorporated in the fuel tank to stop fuel surge & loss of fuel under hard cornering. I would suggest you plumb as per diagram & fit a swirl pot & hp pump engine end. See the following for swirl pot.
http://www.nfauto.co.uk
Ian
sclay115
Post by sclay115 »
so that's a pretty good setup then? it just looks a little 'out there' for me, and i thought it was just some thrown together design, but i was reading up on the Z car forum, and a user has the same setup running an RB26DETT with it, so i'm pretty sure it can handle my comparitively light fuel load....but thanks for the info.
steve
sclay115
Post by sclay115 »
oh and GREAT website! that is some awesome stuff on there, all the little things you never think about when building a car....too bad they are in the UK, nice to see international shipping though...anyone know of a place like that in the states?
steve
elansprint
Steve this saves having to get at the tank & underside etc & the 240Z pump should easily keep the swirl pot topped up. If you looked at the website i am in build with the ferrari P4 on there & am using this set up for the cosworth turbo engine
Ian
Would the fuel tank and high pressure pumps from an injected 280Z fit in your 240Z?
I don't have the option of using a baffled tank for my Dart, at least not without spending a lot of money. I also didn't have many tools to build my own surge tank. So I'm using a trick that I learned on this forum. Here's a website about using a spin-on filter for a surge tank.
jayroc
Post by jayroc »
I have a surge tank on my previously carbed 84 rx7.
The regulator returns to the surge tank, but the surge tank also has a return line going back to the tank. It works well for me.
sperry
Post by sperry »
I made my surge tank out of a small oxygen bottle and just tapped and sealed the fittings and never saw a drop of gas!
you could use a propane bottle from autozone or something but make sure you fill it up with water before you pop the saftey valve out
total project cost wil be 10 bucks for bottle and fittings
renns
Site Admin
Post by renns »
I'm running a surge tank in my '79 rx-7, but I wouldn't go that route if I had to start over. The system complexity, number of hoses, connections, second pump, etc. is needlessly complex.
What I would do if I were starting over, is to modify my existing fuel tank to accomodate a conventional in-tank pump. Others have done this by cutting out the mounting flange from a tank at the wreckers, and having it welded to the top of the existing tank. This allows dropping a standard fuel pump assembly down into the tank. A small slosh pot is added inside the tank to surround the pickup to prevent starvation when cornering at 1/4 tank. Now you've got an 'oem' type installation, with a simple supply and return line to plumb up to the engine. Boy, just talking about it makes me want to go out and mod my tank...
Did the 280z's use an in-tank pump? If so, you might look at swapping in a tank from that model. BTW, love the 240's. I owned three of them years ago. They biodegraded very quickly in the Canadian climate, but were lots of fun till the frame rails let go!
Roger.
1979 Mazda RX-7, running MSnSExtra029L for fuel and spark control on a turbocharged, intercooled, and
(of course!) injected 13B rotary.
jonfx4com
Post by jonfx4com »
I tried a facet gold top low pressure fuel pump to fill a surge tank before the HP fuel pump and it was a hopeless case. The flow rate of the HP pump was way higher than the LP pump and the surge tank was empty within seconds of the HP pump running up. Result was a dead HP pump. You need to look at the flow rating of the LP pump and compare it with the flow rate of the HP pump when its holding 43PSI. The calculation is surprising, you will need a hell of a LP pump to keep up with the HP unit. I suggest you mod the tank and fit an in tank unit, it will save you lots a grief later in my experience.
If you look here
http://www.fuelsystem.co.uk/new_page_8.htm
you will see that my HP pump holds 3 BAR at around 3 litres a minute but a facet competition LP fuel pump can only pump 35 Gals / Hour which is 2.6 Litres / Minute. Result is an empty swirl pot!
I suppose if you find a BIG LP pump it can be made to work but then your paying money to bodge the job when less money will do it right.
Jon
Jon
