2 vehicles 1 microsquirt
hegel
Post by hegel »
I have 2 sets of throttle bodies and I'd like to fuel inject both my 1977 goldwing and 1969 karmann ghia. ignition will remain stock on both for now so firing order wont be an issue. is it possible to use the same brain (microsquirt computer) for both vehicles? does microsquirt learn the vehicle each time or is it more it learns and then retains the information.
thanks,
Steve
Re: 2 vehicles 1 microsquirt
You could do this but would need to load a separate map for each vehicle. At least that would be the easiest way to go. You *might* be able to size the injectors so the Required Fuel for both of them is the same and use MS2/Extra's VE table switching, but there are several other things that wouldn't switch so this would be a compromise.
I'd say you'd have two project files, and just upload the required project to the MicroSquirt for each respective vehicle. It's unlikely you'd have the same trigger wheel patterns, fuel rates, etc plus the sensors would be calibrated differently etc, so you'd be best to treat them as separate entities.
The MicroSquirt doesn't know anything about its operating environment other than the parameters it is fed, so by its nature it is adaptable, and more than capable of switching between vehicles with a reprogram. This is no different to my experiences using the same unit to run on my GTS1000 or a YZF1000 projects.
