any 1 ever used innovate lm1 ???? 2 questions
xr3iturbo
Post by xr3iturbo »
ok just got lm1 put bung in front pipe ,done free air cal- out of exhaust,placed sensor in f/p started car up and the readings are all over the place ie afr is 20-35???? hope this is not right ,even hen car is warm it still same,this is on idle and reving. any help??
also i have changed out put settings for ms 0v=10afr +5v=20afr is this correct, do i have to change any thing else so the readings are the same from lm1 to megasquirt ie impeadence etc in advanced options
thanks in advance
tommy :)
efahl
Post by efahl »
Tommy,
Did you set the proper sensor in the MegaTune configurator, look in settings.ini and change LAMBDA_SENSOR to correspond to your LM-1?
Eric
xr3iturbo
Post by xr3iturbo »
yes i did i set it to match sensor :D
bimmersquirt
Post by bimmersquirt »
have you reprogrammed the LM1 analog 2 output to the 0/5v range required M8 ?
I have an LM1 , I use it to swop the WB between projects easilyt, no issues at all with it, the AFR on the LM matches that on MT perfectly
xr3iturbo
Post by xr3iturbo »
yes i set it0-5v in analog out put on both channels??
