It has been a *steep* learning curve, but I'm looking forward to the possibilites
Thanks to all behind this system and the forum!! And thanks to macky322 for setting me up with the MSII...
Questions: Hot idle is RICH: ~11:1 - is auto-tune recommended/possible for tuning the idle a/f's (if I set the parameters to make it possible - including the .ini file)? or should I just adjust the VE bins 'around' idle?
Another thing, I'm running a seperate filtered air supply to the stock ISC valve (instead of connecting it to the intake pipe). I didn't think this would be a problem with the way MAP works..... Anyone see a potential problem?
