No Spark
No Spark
I can not figure out why I am not getting a spark. Here is my situation
So last year we ran a KTM 560 single cyl controlling fuel and ignition and it worked great. That setup was a running a v2.2 Microsquirt module with a BIP373 controlling a diyautotune IGN-1 coil. This year we are running a Kawasaki 450 single cylinder with a v3 Microsquirt controlling fuel and ignition. My thoughts were "Hey ill just copy my tune and mimick my setup for this year because last years worked". But this were my problem comes into play. I am using the stock coil off of a 2012 Kawi 450 quad. The coil only has a hot and a ground post on it. My thoughts were that I could just run the ignition output to the coil and everything should be A-OK.
I am getting RPM and my injector is firing so its gotta be something on the ignition side that I am just completely missing. I will upload my tune and a data log.
Thank you all for the help,
Robert
- Attachments
- 13.msl
- (45.42 KiB) Downloaded 88 times
- 2013-01-14_21.36.11.msq
- (29.96 KiB) Downloaded 94 times
Re: No Spark
Re: No Spark
Re: No Spark
I will just try to wire up our old inductive coil from DIY that we ran last year and see if it works. I really dont want to run a CDI module. Everything seems pretty clear to me now. I was getting all the CDI stuff mixed up.
Re: No Spark
Re: No Spark
If that is the case then I just found my problem.
Re: No Spark
- Master Squirter
Re: No Spark
I think the changes to the ignition system have been documented and discussed before, but the reason it doesn't have the drivers built in (v2 had jumpers so you could switch & isolate the built in 2 coil drivers and use logic level outputs), was probably, it reduced the chance of failure, noise & interference, plus the packaging was smaller without heatsinks etc. As the MicroSquirt was fitted to more installations patterns of troublesome areas were seen, and it's logical for developers to make this process as hassle free as possible, and isolating high current nasty feedback from sensitive electronics is part of this. Hope this helps, but at least you are up & running now.sn95.ohh wrote:Would have been nice to know that the v3 does not have the coil drivers. Why does it not have the drivers?
PS I have used both the internal & external drivers on my v2 projects, and external really is the better option.
