wasted spark injection timing angle
sn95.ohh
Post by sn95.ohh »
Hello all,
I have a single cylinder with a missing tooth crank trigger wheel. I am using autotrigger mode.
I have a quick question about injection timing angle. Since I am using wasted spark with a missing tooth crank wheel should this value be between 0-360 degrees?? or is the microsquirt capable of recognizing 0-720 degrees?
I have had the engine running but it has a hard time starting and I think this value has something to do with it.
Thank you
Formula SAE
RoadRunner Racing UT-San Antonio
www.roadrunner-sae.com
Re: wasted spark injection timing angle
For your case I would set it 0-360 deg. What is important is that whichever rev you start synch on, you do not inject during the valve overlap period.
sn95.ohh
Post by sn95.ohh »
Thank you for your fast reply and sorry for my late response. Shortly after I posted I went ahead and tried a number between 0-360 and it worked out great. The engine fires right up. Thank you for your help!
Formula SAE
